Hi Tapio,
Sorry for the delay I missed this.
Question: What do you mean by: "JP4-15&16 with voltage dividers is even less appealing"
I believe that should work as an open collector drive without any problems. Because the drive input has an LED and resistor in series it is ok to connect the + terminal to +5V and the - terminal to JP4 pins 15 or 16.
HTH Regards TK
Message: 12200 |
Date: 9/4/2015 |
Subject: Re: Connecting stepper motor? |
appealing" means that I tought inputs to JP4-15/16 be above 3.3V.
Today I tried connecting connectig
+5V->drive->JP4. With IO screen I see that bits 24&25 get configured
as outputs and bit 25 toggles according to direction change but I
don't get movement. I can measure 3.6/0.11 VDC
between drive input(JP4 side of the input) and ground, according
to the state of the output.
It seems that the signal is not quite strong,
missing perhaps few tenths of volt.
Moving the wires back to FETs I again have
movement.
Rgds,
Tapio
----- Original Message -----
Sent: Friday, September 04, 2015 9:13
AM
Subject: Re: [DynoMotion] Re: Connecting
stepper motor?
Hi Tapio,
this.
Message: 12201 |
Date: 9/4/2015 |
Hi Tapio,
Are you using open collector mode? OutputChan0=3 not 11.
Those voltages would indicate the drive is seeing:
5 - 3.6 = 1.4V
and
5 - 0.11 = 4.89V
So the drive input is probably never quite turning off.
On the Digital I/O screen you can simulate the open state by turning off the output. The voltage should then go to about 3.85V and turn off the drive input.
movement.
Rgds,
Tapio
AM
stepper motor?
Hi Tapio,
this.
Message: 12202 |
Date: 9/4/2015 |
I have FPGA(STEP_PULSE_LENGTH_ADD)=62 + 0x40;
When I push "Move" in step response screen I see
destination changing in Axis screen and bit 25 in IO screen changes state
accordingly.
the step bit 24 doe not appear to change, but
I suppose it is too fast for ioscreen to show the change.
I'll try OutPutChan=3 or is that a
typo?
Would a series resistor help if it is due to input
not turning off.
Rgds,
Tapio
Sent: Friday, September 04, 2015 7:25
PM
stepper motor?
Hi Tapio,
11.
5 - 3.6 = 1.4V
and
5 - 0.11 = 4.89V
input.
less appealing" means that I tought inputs to JP4-15/16 be above
3.3V.
configured as outputs and bit 25 toggles according to direction change but
I
ground, according to the state of the output.
movement.
Rgds,
Tapio
AM
Hi Tapio,
this.
appealing"
Message: 12206 |
Date: 9/5/2015 |
Hi Tapio,
That sounds all correct.
My bad on OuputChan0=3 (that would be for JP6).
The Step bit will toggle too fast to be seen toggling on the Digital I/O Screen. But if you continuously Jog at a high speed like 100000 steps per second then there should be a significant percentage of the time high and low and the state on Digital I/O screen should randomly toggle high and low.
I've never heard of a case where open collector mode did not turn off the input. But a series resistor or probably a diode in series (~0.6V drop) might be worth a try.
Take care to not have two axes configured for the same Step/Dir generator since the last power cycle.
What Version are you using? There may have been a bug regarding muxing and open collector mode in one of the older Versions. I just tried V4.33q and it works.
Message: 12211 |
Date: 9/6/2015 |
I'm using V432. I checked the changelogs and the
mux bug was mentioned in 429->430.
Just to be sure that I don't have a
misunderstanding:
Since I have movement when the step wire is toggled
by FET the movement should be there by changing the wire from FET to
JP4-15, presuming that muxing is OK.
I have encoders 0-6 in use. Can that have an
effect?
I figured I try CW/CCW mode tomorrow.
Rgds,
Tapio
Sent: Saturday, September 05, 2015 7:50
PM
stepper motor?
Hi Tapio,
That sounds all
correct.
for JP6).
cycle.
Message: 12213 |
Date: 9/6/2015 |
Hi Tapio,
Yes that mux/open collector bug should have been fixed by V4.32.
I assume that when using the FET you have the drive + input connected to +5V the same as with JP4-15 ?
Don't forget to try the Jog at 100000 test in the previous email.
Also try toggling IO25 from Output/Low to Input to see the voltage levels and if the drive steps (note the I/O must not have been configured for Step/Dir).
You might also try inverting the pulse with: FPGA(STEP_PULSE_LENGTH_ADD)=63 + 0x40 + 0x80;
Sometime inputs have slower rise times than fall times soone polarity of pulse will work and the other wont. The FET method would be much longer than the 3.78us max pulse.
HTH Regards TK
From: "'Tapio Larikka' tapio.larikka@... [DynoMotion]" <DynoMotion@yahoogroups.com> To: DynoMotion@yahoogroups.com Sent: Sunday, September 6, 2015 1:55 PM Subject: Re: [DynoMotion] Re: Connecting stepper motor?
misunderstanding:
effect?
Rgds,
Tapio
PM
stepper motor?
Hi Tapio,
That sounds all
correct.
for JP6).
cycle.
Message: 12218 |
Date: 9/7/2015 |
Movement! <:-)
Adding a series diode did the trick!
As general question about steppers:
It looks like max speeds above 1200 cause the motor
(without load) to loose sync: movement stops , motor loses torq and
oscillates until steprate decelerates.
Drive voltage is 24VDC, drive set to
400step/rev.
Is this normal for stepper motors?
I did know that steppers lose torq as speed
rises but this was surprise to me. I expected usefull torq to
500-600rpm
Thank You for your help,
Tapio
Sent: Monday, September 07, 2015 12:31
AM
stepper motor?
Hi
Tapio,
the pulse with:
pulse.
stepper motor?
misunderstanding:
toggled by FET the movement should be there by changing the wire from FET
to JP4-15, presuming that muxing is OK.
effect?
tomorrow.
Rgds,
Tapio
PM
Hi
Tapio,
That sounds all
correct.
low.
try.
cycle.
works.
Message: 12219 |
Date: 9/7/2015 |
Hi Tapio,
Strange I'm not aware of another case where such a thing was required.
Many Steppers have reduced but useful torque up to 500-1000RPM
Those motors are very high resistance, voltage, and inductance motors so I would expect them to have rapid torque drop off. Normally a supply voltage of 10-15X higher than the nominal DC coil voltage is used to be able to force current by being able to overcome the inductance and back-emf of the motor at speed. Those are 12V motors so a 24V supply is only 2X higher. Consider replacing the motors with something in the 2~3V range.
HTH Regards TK
Message: 12235 |
Date: 9/9/2015 |
I chose this motor because of the very low current
demand, since my 24VDC psu was already almost maxed out.
By adding separate 48VDC psu and gearing and using
more microstepping I got the speed up to 6800 steps/sec which results in good
enough perfomance.
I'm going to add an encoder tomorrow and then this
assembly is close to ready.
Next time I know what to look for when I choose
steppers.
Thank you again for your help
Rgds,
Tapio
Sent: Tuesday, September 08, 2015 3:46
AM
stepper motor?
Hi Tapio,
